I have a 1964 dodge a100 pickup, and am installing front disc brakes. From what I have found out, the A100 pickup weighs around 3000lbs. I need to find a brake proportioning valve . I've located a 1987 D150 (unsure of engine/options/pullapart). Would anyone here know what the weight of the 87 D150 might be ? Would the proportioning valve be a good choice to use on my 64 A100 pickup ?
I should also note that the brake system is manual brakes..not power.
Brake proportioning valve for disc swap
- City: New Franklin
- State: OH
Re: Brake proportioning valve for disc swap
Get an adjustable one for the rear brakes.http://tse1.mm.bing.net/th?id=JN.E%2fNu ... d=3.1&rm=2
This is what I used on my conversion to scarebird this past weekend...works great.
http://www.ebay.com/itm/GM-PROPORTIONIN ... 210wt_1001
- State: OH
I did locate a 1987 Dodge D150. Unsure of weight and options. Possible choice ?
Yes.RUSTYTOOLSS wrote:I did locate a 1987 Dodge D150. Unsure of weight and options. Possible choice ?
- swptln
- City: East Brookfield
- State: MA
RamMan.com has everything you will need and it wont be aftermarket or brand X stuff. You will have to call him, he doesn't have much stuff listed on his site.
http://www.theramman.com/
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
Im trying to add disc brakes to the front of my a100 pickup. Where did you get yours or what did you use??
Thanks in advance
Tom
Thanks in advance
Tom
