I've been researching tire sizes. I've got to get the 31/10.50s off the truck. Its a bugger to get rolling and turning is kinda rough. I'm just going to buy tires locally. The FSM and it shows a 6.70 or a 7.10 for a D100. I looked at several tire conversion charts and this seems to be the converted size to a modern tire. I have a 64 Utiline with a /6 and 3.91 gears. I calculated rpm at 60 mph. I read that the recommended tire size is 235/75/15 here by members. My wheels are 15X7.
6.70-15 is a P205/75R15 and 7.10-15 is a P215/75R15
205/75R15 = 27.1X8.07R15 2909rpm
215/75R15 = 27.7X8.07R15 2846rpm
225/75R15 = 28.3X8.07R15 2785rpm
235/75R15 = 28.9X8.07R15 2728rpm
Two questions:
Which size would look the best and be easy on the starting and turning?
Anyone else with the /6 and 3.91? What size do you have and if you changed what size would you get?
Thanks, Craig
Tire size confusion
- my5thmopar
- City: Columbia
Tire size confusion
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
Re: Tire size confusion
I have 235/75/15's on my '61shorty. /6,3:91. handles just fine.
- my5thmopar
- City: Columbia
Thanks, I'm bumping this for more suggestions.Txas2step wrote:I have 235/75/15's on my '61shorty. /6,3:91. handles just fine.
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
- Commando66
- City: Gig Harbor
I like the 235/75's on my truck. They're Cooper Trendsetters. Easy to turn and they handle pretty well.
[IMG]http://i270.photobucket.com/albums/jj104/Commando66/DSC03735_zps507e925c.jpg[/IMG]
i have a 318 with 3.5 rear and i can't think of any complaints with the size.. but I guess i don't have much to compare it to either.
i used 235/75-15 but mostly because that's what was already on there and also because that is the stock size for a Jeep Wrangler,
which meant I was able to find 5 lightly used tires and rims on craigslist for $120..
unmount/remount and balance was $100,
sold four of the bare wrangler steelies for $80,
kept the last wheel + tire for a spare (mine was missing)
not a bad deal i think
- swptln
- City: East Brookfield
- State: MA
Also, you might want to consider the type of tire you choose, P-series tires are more passenger car related vs a LT type tire. A P-series will give you a better ride and they will have a lower psi rating usually a P-series tire will be rated at 35-45 psi. A LT type will be rated at 50-80 psi and will give you more of a truck ride.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
- 66patrick
- City: Central
The narrower the tire, the easier it is to turn the steering wheel, regardless of the vehicle.
I've got P235-75R15 radials on stock 15" x 7" Mopar steel wheels on the unmodded '68 D100, and the truck rides and drives great.
- my5thmopar
- City: Columbia
Thanks guys! I went with the p235/75/15 on my Kelsey Hays steel 15x7 wheels. The truck is so........easy to steer now. The tire size looks correct. Thanks for the advice and comments.
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
