Steering Box Grease/Dust Seal???
So I'm now putting al of these things back together on my '66 D100 Town Wagon and am wondering if there is a source for the grease seal and dust boot that goes around the lower part of the steering column, where it slides into the steering box???
Re: Steering Box Grease/Dust Seal???
I did mine on my 64 Town Wagon a few years ago. The good news is that the coupler is the same one used on Jeep CJs through the late 80s, so any 4x4 shop will carry the parts. I replaced the bearings (the small square blocks) at the same time.
Just Google the part numbers you should come up with some sources.
Good luck
Mike
Good luck
Mike
Thanks Aqmet. I searched the part #'s you gave and actually found a kit that had the the dust seal and the other 2 parts you referenced as a kit!
http://www.summitracing.com/parts/omx-1801802
Thanks for the info!
