steering knuckle bolts dana 44
- lightning4x4
- City: cave junction
bought a lift for my70 w200 as I have not driven this truck yet I found that the bolts, cone washers, that hold the steering arm to the knuckle are gone(two wrong bolts hand tight) .which explains why it was so sloppy. my problem is where do I find a place to by new ones? most of what I found on the net is two large (diameter) or are they the same size studs as a dana 60?also is there a place to get a steering lift block for this light duty dana 44? thanks
- powerwagon54
- City: Washougal
Re: steering knuckle bolts dana 44
I have the studs, nuts and cone washers for the steering arm if you want good used
