Scarebird brake install HELP needed!!
- moparbay
- City: Rapid City
- State: SD
I am in the process of installing the Scarebird front disc conversion and have run into a snag. The drivers side caliper will not clear the steering arm. The bottom of the caliper hits the steering arm and I am at a loss of what to do next. Here are some pictures the last picture is the picture in the instructions (not sure what truck they used but the steering arm is on the back side of the spindle and the steering gear is in front of the axle???):
Has anyone else run into this issue and how did you fix it? Thanksmoparbay
Ole "Blue" 68 D100 Adventurer
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
- City: Glendale,
- State: AZ
Re: Scarebird brake install HELP needed!!
I am not sure, but it looks like you have the right caliper on the left side and vice-versa. Check it out from my D200. Jim
03 Hemi Ram 2500
- moparbay
- City: Rapid City
- State: SD
I thought of that so i read the instructions again and it said the opening of the bracket faces the front of the truck. I have an email in to scarebird but i may just reverse the sides tomorrow and it should fit like that.JimE wrote:I am not sure, but it looks like you have the right caliper on the left side and vice-versa. Check it out from my D200. Jim
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
It appears you have them on backwards. The calipers should be to the rear.
- Attachments
- Slide7.JPG (21.39 KiB) Viewed 1875 times
- moparbay
- City: Rapid City
- State: SD
They might be on backwards, if so, scarebird needs to change their instructions. I will let you guys know what they say when they reply to my email. Thanks guys for the help
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
- moparbay
- City: Rapid City
- State: SD
They might be on backwards, if so, scarebird needs to change their instructions. Scarebird agrees, they are on backwards. I guess I need to review the instructions for the 26th time to see if I over looked something, but I am positive the instructions are wrong. This must be early signs of senility. Thanks guys for the help.
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
- mousecat
- City: Modesto
I would have to agree with the others, might be on backwards. I just got mine all plumbed and working a few weeks ago, and they are working Great!
Yes the instructions are wrong and I informed Scarebird of this. The caliper mounts to the rear, not the front.
- flyinbrick68
- City: north platte
- State: NE
Make sure you put the calipers on the right side also with the bleeders facing up... You'll never get em bled with them on backwards...ask me how i know...
- City: Newberg
There are many caliper assemblies that have bleeders at the top and some that have them at the bottom. There are some that have both top and bottom bleeders. While bleeding top mounted bleeders may be easier, bleeding bottom located bleeders is still achievable.flyinbrick68 wrote:Make sure you put the calipers on the right side also with the bleeders facing up... You'll never get em bled with them on backwards...ask me how i know...
- EM
- moparbay
- City: Rapid City
- State: SD
Thanks for all the help, I have the kit installed and bled. I am waiting for the weather to warm up to install a proportioning valve in the rear brakes to improve the pedal.
moparbay
65 W100
67 D400
67 W100 (in pieces)
65 W100
67 D400
67 W100 (in pieces)
if any of you need a scarebird conversion or know of someone who wants one, i am selling a complete axle from disc to disc. ill save you or someone some cheddar and sell the whole thing for $500. steering gear box linkage and leaf springs included if you want them. I'm located in phoenix, az.
1966 Dodge D100 Custom SC SWB
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
