Crown Vic IFS track width?
- cudajimmy
- City: Oklahoma
Anyone here done the Crown Vic IFS subframe? I'm thinking about doing this, but I need to know the track width of the Ford. If it's wider or more narrow than the factory Dodge straight axle. I've already got the wheels I want and I'm not looking for any weird offset crap or wheel spacers.
Info anyone?
Info anyone?
69 Barracuda Notchback 440
61 D100 SWB Poly Auto
Re: Crown Vic IFS track width?
I'd suggest doing a site search, as there is a lot of information on various front
clips.
clips.
- 66patrick
- City: Central
The '92 - '02 subs use the same offset wheels as our trucks do. The '03 - '13 cars have a positive offset wheel. The truck frame does require notching. From what I've heard about the install of the CV/GM sub, the ride is improved tenfold over the stock straight axle. I might do this to the stock '68 I have, if I don't sell the truck first.
A guy out here in CA said he would convert mine to a Crown Vic IFS, handle the motor mounts, power steering, steering shaft, and power brakes for $2500. He also said the width is 67", which would be very wide. I haven't verified any of this or decided if I'm going to do it, since I haven't seen his work.
flipp, is that guy in CA in Southern Ca? I'm considering something along the same lines. Please keep us posted.
- City: mission
you need an 04 and up sub frame to get the aluminum bolt one one the ealeyer ones are part of the chassis.
- City: Clinton
The front end runs anywhere fro 150. to 300.00
- City: mission
67-3/8" wms
found it
found it
http://sacramento.craigslist.org/pts/4682655399.html - He is in Valley Springs, CA. Again, I can't vouch for his work or prices, but he is an option.babbabuee wrote:flipp, is that guy in CA in Southern Ca? I'm considering something along the same lines. Please keep us posted.
- City: strathmore
wow 2500 hundred do it yourself a good welder cost 500 and you dont need to do a major cut on the frame just cut it so you can push in the rails
