w200 king pins
- marine43
- City: glenshaw P.a.
w200 king pins
Hey Guys, truck failed inspection. Needs new king pins. And i reckon I should change U joint while in there. Anybody have the info on w200 pins and joints? I can't find. NAPA no luck. Everything else only half ton parts..... Thanks!
- jimmy
- City: Spokane
Re: w200 king pins
Sorry I don't have part numbers and don't know if you can get them. Hard to find parts and obsolete stuff drive me crazy.
I converter to a 92' dana 60 for that reason, plus you also gain disc brakes.
The Heavy duty dana 44 from the 80's to 93' is also a good axle and cheaper to buy.
Axles from Dodges in the mid 70' to 93 will bolt right in. Spring spacing is the same.
Parts are at every auto parts store. Brake parts, ball joints, Open knuckles, seals gaskets, no drums and wheels cylinders!
Just a thought, thats all.
- PowerMan
- City: Auburn
Re: w200 king pins
Small or large knuckle??
Give Vintage Power Wagons a try.
- marine43
Re: w200 king pins
Not sure yet haven't taken apart, might need truck in a week and didn't want to pull apart till i had all the parts. Was gonna get both ujoints offered at NAPA and just return un used ones. Forgot about vintage! Will look thanks! JimPowerMan wrote:Small or large knuckle??
- RussRoth
- City: Vancouver, WA
Re: w200 king pins
Six States had all the parts needed for mine.
