Straight Axle Drop
Straight Axle Drop
O.K.
I woke up this morning thinking on an inexspensive way to drop the front, after crawling underneath yesterday and trying to see if their was something I missed, :idea while laying in bed I was thinking about the axle flip, we know that the drag link will hit the leaf springs :thinking but how much room would be needed to free up space for the drag link to clear the leaf? :study can it be accomplished by using the lift bars and using the reverse philosophy? :study by putting the lift bars in between the leaf and the straight axle, and the straight axle on top of the leaf, could be a 4" drop? responses would be nice :idea
cowboy
Post by cowboy »
Robin , why drop a damn good truck ? :joker , I took a half way look at hotrodjohn's & it look pretty good , but it looked like he cut & droped & welded it back seems to work for him , I knows he drives it every day
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
axle drop
Cowboy my trucks front is too high, I need to get it down without loosing drivability, I've been contiplating the way to do it without spending hundreds of dollars :Thumbsup
Guest
Post by Guest »
hey buddy, i have a 62 d100 and I had lowered the front of it about 5-6 inches while only spending $16. It cleared the draglink but after i let it settle the straight axle was just way too close to the oil pan for comfort. Hope this helps you. I bought a pair of spring perches from summit and used them just like you would on the rear if you flipped the rear axle. You will have to notch the center of them to be sqaure instead of round so that it will fit snug on top of your axle. I added a pic of the perches so you know what i am talking about. I know this is hard to visualize so i will send you some drawings if this does not make sense.
Jared
http://81x.com/Authors/clean_rx8/spring_perch.jpg
drop
O.K. Jared
I think that is exactly along the lines I was thinking, you have those perches inbetween the leafs and the straight axle, with the axle on top, U bolts go through the perches also? which oil pan and engine did you have? :thinking :study
cowboy
Post by cowboy »
Robin , just messen with ya , as you know I use my truck as a truck & haul trailers & anything else , I just added a pipe bumper the rear , & would like about 1-2 inches taller , Just yesterday I had the lowboy hooked up & loaded with A bunche of tree branches , we cut down & put out back to cut up for the BBQ pit (pecan trees)
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
Guest
Re: drop
Post by Guest »
MountainMoparRobin wrote:O.K. Jared
Yes the perches were in between the axle and the springs with the springs on top. The perches gave me the necessary clearance i needed to clear the drag link. I have a 225 straight six with a front sump oil pan. I have since pulled all of the factory suspension and am putting in a mustang ii.
Jared
Ramit
Post by Ramit »
When I need to adjust ride height on leaf springs I just heat a line across the spring about 4 inches from the shackle end while measuring distance to the shop floor from the frame with a tape measure. You can raise them this way too with a bottle jack between the spring and frame. :2cents :thinking
slick
City: Tucson/AZ
Post by slick »
Jared,
do you have any pics of the setup on your truck...or how it was setup..
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
Guest
Post by Guest »
sorry i dont have any pictures because i wanted it super low in the front and i just couldnt get it there and have good axle clearance in relation to the oil pan with the leaf suspension. I did have to notch my axle though to clear my oil pan. Sorry, I can draw a picture of how it was in there if you need to see it or i can mock up the leaf suspension out of the truck and take a pic.
Jared
Drop
Ramit
I'm a little unclear on your procedure to drop the axle height with using heat and bottle jack? :study
Guest
Post by Guest »
he is just saying that you can heat the springs up until it lowers to the height you want it at, or if you get it too low you can jack it up while heating the springs until you acheive the height you want. Or you can take the springs out and have them de-arched professionally at a shop that does leaf spring service, like a semi or truck leaf spring place.
Jared
bad383
Post by bad383 »
I have a 1971 d100 and I lowered my front end 6" by setting the axle on top of the spring. After alot of messuring I basicly welded a new spring pad on the bottom of the axle. I havent had the truck on the road yet but its looking promising. I dont have any oil pan or steering linkage clearence problems. Also I need stainless trim for the truck. Its a short box. Let me know what you got.
straight axle drop
the drag link clears the springs? how did you manage to get the drag link to move without hitting the leaf springs?
Guest
Post by Guest »
I didnt do anything. It did it by itself. I welded a new spring pad on the opposite side of the axle which was about 1" thick. This new pad has the u-bolt holes and centering hole in it.it worked out pretty slick. I also droped the rear in the same fashion. I welded new sprong pirches on and mounted the axle just like a car.
POWWAG
City: Maple Valley
Post by POWWAG »
Robin
I was under the 65 D100 I just picked up and it looks doable. Weld the new spring pads on ,trim the old ones off, have the taper reversed so the tie rod goes on top. Shock mounts stay under the springs for stock length shocks. Stare at yours and give me feedback.
It's been a long time since I've delt with a 2WD, I'm use to lifting them.
Don
POWWAG
it can be done, except on mine it would need additional help for the drag link and tie rod ends to clear the springs, but maybe using the lift spacers in the opposite way could possibly give the needed clearance, however I don't have a welder either so will have to wait. :Thumbsup
hemidart1
flip
Post by hemidart1 »
my buddy who flipped the rear of my truck is going to flip the front next month. I'm hoping all is okay. I think everything should clear if you have a rear sump pan.
anyhow I'll get him to take pics when he does it.
al.
straight axle drop
I for one would be very, very, did I mention very interested in seeing it, if you don't post the pictures please at least email them to me :Thumbsup
wideblock
City: las cruces nm
State: NM
Post by wideblock »
robin, do not, i repeat do not use spacers between the spring and the axle. this gives some servere steering issues when braking. thats why you never see blocks on the front of a lifted 4x4. my truck had about 1 inch of "lift block" on it when i got it. it was acctually the wedges for pawer steering that had been reversed to form a block, but anyway, it was a night and day difference on how the truck held the road once they were removed. :Thumbsup
