71 d100 power steering.
- City: Weston
- State: MO
Does anyone know where to find the parts to rebuild the power steering system on my 71 D100? I guess I am looking for seals, gaskets and small parts! Thanks
- Roxyflash
- City: East Moline
- State: IL
Re: 71 d100 power steering.
The control valve is basicly two orings unless the rod end is worn.The cylinder has a seal on the end other wise not a lot you can do unless you cut the cylinder in half.What parts are bad?The hoses can be retro fitted with adapter fittings too use jic fittings and standard hydraulic hose.I will be in the process of rebuilding a setup for my 1966 d200 which is manual steering.
- Roxyflash
- City: East Moline
- State: IL
To convert hoses to jic fittings which are easy and cheap to find heres a link
http://www.pscmotorsports.com/5-8-18-x- ... apter.html
http://www.pscmotorsports.com/11-16-18- ... apter.html
