brake light sensor
- duracell
- City: Peoria,Arizona
brake light sensor
does any one have a working one that fits a 1970 d100 previous owner cut the wire to it because the brake light stayed on all the time
- Jeffc
Should be able to pick one up at Napa, I assume it
is the one behind the brake peddle.....
Often the cause of this is a miss adjusted brake
return spring or worn/dirty peddle shaft, sticky
master can also be part of the problem.
Or are we talking about the dash light low pressure warning brake light on this truck.......
