Went to get shoes,spring kit and wheel cylinder rebuild kit for the front of my 64 D100 at Auto Zone. They had the shoes (same front & rear) but not the rebuild kit (had to be ordered) and the spring kit was N/A. Who has this stuff in stock? Is mine auto adjust or will I need to upgrade? if so is this an usually in stock item?
Thanks in advance, Charley
Front brake parts 64 D100
- City: Murfreesboro,
Re: Front brake parts 64 D100
When I bought my early '65 D100, itCharleyDavidson wrote:Went to get shoes,spring kit and wheel cylinder rebuild kit for the front of my 64 D100 at Auto Zone. They had the shoes (same front & rear) but not the rebuild kit (had to be ordered) and the spring kit was N/A. Who has this stuff in stock? Is mine auto adjust or will I need to upgrade? if so is this an usually in stock item?
did not have the self adjusting front brakes.
It did have the dual piston wheel cylinders.
I converted it to self adjusting brakes.
I buy all of my brake parts at NAPA.
There's a NAPPA one block away from my shop but not open on weekends, I'll check with them tomorrow. Thanks
Nobody seems to have a "kit" just all individual parts. Is there another kit from a different year that will work? if so do you have part #s? also what part # for the auto adj. kit? This is kinda urgent as I have my truck down and also taking up shop space.
Thanks in advance
Thanks in advance
- City: Mesa AZ
The 65 D100 front adjusting kit is H2545 and the all in one kit is H7137 both from Autozone.
- City: SAN JOSE
Does anyone know of this kit will work on a 64 d200?
Haven't messed with drum brakes in 20 years and they were self adjusting so I'm just trying to play it safe.
