HELP -king pin- HELP
- taintedspeed
i havent been around much since the address change but i need some help as i am redoing the front end of my 68. it needs new kingpins. i purchased some of the bearing type kingpins and i dont know if i can do them myself or if i need to take them to a shop. any and all help gladly taken and appreciated. thanks -Randy
all mopar all the time
- wideblock
- City: las cruces nm
- State: NM
you need to be sure you got the bearing type king pins before you try the swap. if you dont, they wont fit. theres a extra bit of clearence machined into the axle for the bearing type king pins. i was gonna be smart on my 66 and use them instead of the bushed type, i was sadly dissapointed when it wouldnt all go back togather. its easiest to do the king pins on the work bench, under the truck sucks. also, did you get nylon pin bushings, or bronze? the nylons can be done in your garage, the bronze ones require a reamer to line them up properly.
