68 D200 wonders when loaded
dan560
City: riverside ca
Post by dan560 »
I have a 1968 d200 camper special. It is a workhorse dumptruck, we are having a problem with it wondering when loaded. We have taken it to a reputable dealer in the area. They cant fimd any thing wrong, so I have come here we want to keep it running. I need some suggestions about what I can do to fix the problem. Any suggestions would help. Let me know if you want to see any pictures or areas you need to see ho help with the problem.
We are willing to get a 68 wrecker to take the front end if we cant fix the current issue.
mowingman
City: Denton, Tx.
Re: 68 D200 wonders when loaded
Post by mowingman »
I wonder What is it "wondering" about, where it's next load will go? Is it a problem, because, due to this wondering, the truck takes it's mind off the trip in progress! sounds like the truck has a mind of it's own since it has the ability to "wonder". :lol: :lol: :lol:
1979 Plymouth Trailduster, 360/auto.
1989 W150 Power Ram shortbed pickup, 318/auto.
1970 W200 Power Wagon long/wide bed, 383/4spd.
MOPAT
Post by MOPAT »
I'm sure he meant 'wander' [spelling cop on here would be a full time job for ya].
To the question:
MIGHT be overloading and putting too much weight on the FAR back.
Might try tightening up the steering box ( it IS adjustable)
Shocks??
73 CJ5 304V-8 Metal Cab
mowingman
City: Denton, Tx.
Post by mowingman »
I thought a little humor would be good for us this evening.
I would suggest you check the tires. If they are fairly old, you could have had a radial belt slip in one, or both front tires. This can show up as a wander, usually when loaded.
Jeff
shdnobetter
City: Elmira, OR
Post by shdnobetter »
Any wear in the king pins, steering linkage, would be made worse by a heavy load in the rear.
dan560
City: riverside ca
Post by dan560 »
thanks guys,
those are the things i had thought just wanted to run this by anyone out there.
to the spelling i just had a redneck monent
and dislexia really helps in a typing situation :banghead
OregonDodgeboy
City: Nampa, Idaho
Post by OregonDodgeboy »
I think that most any truck will wander with a big enough load in the back. But I suggest that you spend a few bucks and replace the rag joint at the base of the steering column. They often get overlooked, and when you pull it off you may be surprised to see how rotten the rubber is. Cheap place to start anyway.
:2cents
Jeff Easterbrook
67 W200 440/4-sp. Resting
76 IH Scout II
81 MB 240D
HEtkind
City: Johnson City, Tennessee
Post by HEtkind »
I have fixed wander problems with spring bushings...
so, if the kingpins and tie rod ends are good, and the truck aligns OK (caster, camber, toe-in), I would look at spring bushings
Howard
Howard
62 Dodge D100 Town Wagon
62 Dodge M-37
68 Dodge D100 Utiline
2007 Dodge Ram 1500ST
