More Power Steering Box Donors Found?
jwing68
City: Lethbridge,Alberta
Re: More Power Steering Box Donors Found?
Post by jwing68 »
It's unfortunate the cpp setup is not working out, I have been kicking around the idea of a crossover setup on my 68 W300 by swapping the knuckles to put the steering out in front for the crossover setup. What do you think fellas is it feasible? :thinking
66 Fargo W100 Sweptline SWB Poly 318
67 Fargo W100 Sweptline SWB Poly 318
68 Fargo W300 dually LA 318
66 Dodge W200 Poly
65 Dodge W300 dually Poly 318
68 Pontiac Firebird 350
2005 HD FXST Custom
digdoug
Post by digdoug »
jwing68 wrote:It's unfortunate the cpp setup is not working out, I have been kicking around the idea of a crossover setup on my 68 W300 by swapping the knuckles to put the steering out in front for the crossover setup. What do you think fellas is it feasible? :thinking
I have a NOS steering arm from an m715 that would bolt on top of your right side 70f knuckle for high steer. I also have a rebuilt 78 f250 box (like Dodgy Dan used). they could both go your way if you think they would work. The steering arm is straight,so I am unsure if it would clear the spring pack as the M715 is spring under. Food for thought. :thinking
91w350 CTD
93w250 CTD
