Check your brake pedal pushrods!!
- devilbrad
- City: Pacifica/California
I'd hate to see this happen to any of you guys. Get under your dash and check your brake pedal pushrod at both ends. Pull the pedal back and make sure it wont fall out of the master and check the bolt or pin on the pedal for wear. Chances of any of you finding a problem are slim, but if just one of you does, then I did my deed for the day. http://www.classracer.com/classforum/sh ... php?t=9497
- achille
- City: Washington
Re: Check your brake pedal pushrods!!
..I zee nothink.
- devilbrad
OOPPSS, sorry, fixed! I'm used to vBulletin message boards!achille wrote:..I zee nothink.
- devilbrad
Is the link not working? Works for me fine. There are no images if you are expecting that.achille wrote:...
