Leaf springs D200
Jonte
Leaf springs D200
Post by Jonte »
Anybody who knows the measurment between the the "loops" of a 1968 D200 front leaf-spring? (Don´t have my truck near by)
digdoug
Re: Leaf springs D200
Post by digdoug »
D and W 100-300 front springs are 48'' eye center to eye center.
Jonte
Post by Jonte »
*#%^, the new one´s I got yesterday from Summit are about 54-55" center to center. They´re supposed to be for 66-71 w200´s :thinking
digdoug
Post by digdoug »
Sounds like rear springs ,maybe?
Jonte
Post by Jonte »
Hope not, they´re marked "Dodge Front"
Jonte
Post by Jonte »
Thank´s for the info digdoug, I meassured them again today and they are 48". Must have been dizzy the other day...
But now I´ve just realized that I need longer U-bolts to fit around the thicker "W"-leafs. (The leafs on my D200 are much thinner)
Jonte
Post by Jonte »
Great progress today, I´ve installed the new +6" W-leafs. And it looks really cool and works just right even though the kit was supposed to be for a newer Dodge truck.
Next step (to tired to do it today) is to install the rear lift with blocks and new u-bolts, and then use the original u-bolts from the back on the front-axel (the original front ones turned out to short, so now I haven´t got the bottom end of the shock´s mounted since the plate didn´t fit).
Will post some pictures later on :dance
Jonte
Post by Jonte »
I´ve just finnished installing the whole lift kit and it looks pretty good! (Will take photos and post)
The Skyjacker kit was for a 1970 -> w200, but all the parts fitted perfect on my '68 d200 except that I needed longer u-bolts for the front. I´m just thinking about one thing, what are the three (THREE) round u-bolts sent with the kit for? (See picture)
The square ones and the two blocks are for the raise of the rear end and the bushings and everything else for the front. (I guess new u-bolts aren´t included beacause the original ones from a 4wd should fit). But then, what are the three round ones for??? :thinking
I think the round u-bolts are for later DANA 44 front axles.
Jonte
Post by Jonte »
Ok, that´s proparbly right. But why 3?
Jonte
Post by Jonte »
(I´m lucky that the whole kit fitted on my truck, I think I ordered for a whole other truck but still it worked :lol: )
Jonte wrote:Ok, that´s proparbly right. But why 3?
The right side of the later DANA 44 axle only takes one.
