slick
Posts: 3096 Joined: Wed Dec 31, 1969 6:00 pm
City: Tucson/AZ
Post
by slick » Fri Sep 07, 2007 5:25 pm
so I figured out why my brakes kept locking up. It's in the master cylinder, the plunger isn't popping back out like it should. Its a new master cylinder, any ideas? thanks
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
digdoug
Posts: 2863 Joined: Wed Dec 31, 1969 6:00 pm
Post
by digdoug » Fri Sep 07, 2007 8:19 pm
Adjust the rod shorter,so there is a little free play in it.Also make sure the peddal return spring is intact.
slick
City: Tucson/AZ
Post
by slick » Fri Sep 07, 2007 9:20 pm
I have adjusted the rod. it comes back out with the return spring, but the plunger stays down and the brakes drag and sometimes almost lock up
1961 Dodge D100
1964 Dodge Polara
digdoug
Post
by digdoug » Fri Sep 07, 2007 11:15 pm
If you have power brakes,you can also adjust the pushrod in the booster.Also the seal can get bunched up behind the master and not let the piston return.Try loosening the master from the booster about 1/8" and see if the brakes release.
slick
City: Tucson/AZ
Post
by slick » Sat Sep 08, 2007 9:55 pm
cool I'll try it...
1961 Dodge D100
1964 Dodge Polara
