Hey, does anyone body know if you can....
Posted: Sun Nov 07, 2004 10:45 am
Run an air-bag supension system in the Sweptlines without having to sub-frame the fronts to a coil over system (probably from like a later Ram, maybe a 93 or something)
Cause i wouldn't mind having an air bag supension system on my D100 since some of the roads around here aren't very smooth and low ground clearence friendly, yet i wouldn't mind still having the lower ride look.
If it can't be done without much fabrication then i'll settle for different leaf springs and tire pakage, but i was wondering since i have limited space and knowlage of sub-framing if it could be done. Thanks
