I'm also gathering info on a '67 W200 4-door Power steering/ power disc conversion. Anyone out there specializing in this field or even offering parts for sale?
Thanks everyone!
W200 Power steering and power disc brakes
IF you use the search function (at the top of the page) you will probably get 10-20 pages of information.
Pat
73 CJ5 304V-8 Metal Cab
- nfury8
- City: KC, MO
There are several options for steering, none a simple bolt on. There is decent info scattered around the site.
There isn't much info on front discs for a W series though. The only option I know of is to swap the entire front axle for an early 80's unit that already has discs. This is actually pretty straight forward, with one exception - Most of the axles you will encounter will be 5 lug, instead of 8 lug. They will also have the open style Dana 44, instead of the big closed knuckle Dana 44. I have a 70 half ton with early 80's axles, no problems.
I am not up on the 80's trucks, did the 3/4 ton and 1 ton trucks still use 8 lugs and have discs?? Or were discs only on half tons? Either way, most Swepts used the same axle for 1/2 ton and 3/4 ton, so an 80's half ton axle would be fine. Going to the 5 on 5.5" lug pattern opens up a whole new world of wheel options also. But I can't help much more to tell you which trucks had which configuration. Wish I knew, I have a 70 W200 crew that I would like to have discs on.
