springs
The springs are stacks of steel flat stock called "leafs" with eyelets at either end of the main leaf with bushings and pins. The front of the front spring will be attatched to the frame via a swinging shackle that is also attatched to the frame with a pin through a bushing. The rear of the front spring is attatched to the frame with a pin through a solid bracket attatched to the frame. This is basically the same for the rear springs. You will get some flexing of the springs when you jack the truck up by the bumper but should not be more that about 6" depending on your shock length. Inspect the length of the springs for cracks or gaps. It should be a continuace piece of steel from front to rear with additional spring leaves stacked below the main leaf.
Hope this helps,
Ken
Hope this helps,
Ken
- Jeffc
mmmmmm, can't even recall the last time I jacked up
a truck with a bumper jack??? aways use a bottle jack
or floor jack on the axle. Keeps those "hard to find"
nice clean bumpers un-tweeked and a little safer too.
- wideblock
- City: las cruces nm
- State: NM
i used to jack my 66 up by the bumper with the big farm jacks. it will come way up before the axle ever leaves the ground. you sure you just didnt go high enough?
- oneowner71
- City: Fort Worth, TX
I'd with trey on that one... I've had to go almost all the way to the top of the bumper jack just to get the tires high enough off the ground to get the bottle jack underneath the axle... quite a good bit of suspension travel... though I guess it would have been better if the axle wasn't burried in the mud at the time
Thanks, Clint
1971 D-100, 318 3-spd
1970 Dude, 383 / A727
1971 Plymouth Satellite,
2002 Dodge Ram 1500 Quadcab
Just in case this is what Aceway has. Doesn't the camper special have a second leaf spring that isn't attached and doesn't touch unless there is some serious weight on it?
Matt
Matt
66 D-100 long bed swept
Shearingmatt@yahoo.com
my 70 d200 came stock with dual rear springs. there is a bumper of sorts wielded to the frame and when i put tons of stuff in the back the second spring stack will rest on the bumper of the frame. all in all i think my rear leafs are about 12-16" think. rides like a skateboard when empty as a result. also it does take a lot of travel to lift the wheels off the ground when jacking the truck up via bumper/frame
tom
tom
- wideblock
- State: NM
to add to hoss's post and answer your question, no the coils arent hooked to anything up top. they are an aftermarket overload spring, bolted to the axle, and just comes in contact with the frame or a plate when loaded. they just kind of float in space otherwise.
