master cylinder
reallylongnickname
City: Ottawa, Ontario
master cylinder
Post by reallylongnickname »
I replaced the master cylinder, but it does not fit right. The rubber piece ( diaphram ) does not fit into the brake booster. Is there another master cylinder with a different end on it i wonder? I dont have the original master that was on there. It is drum brakes all the way round.
Russ
Post by Russ »
If you are referring to the bell shaped rubber cover that covers the pushrod, you don't use that when you have power brakes. Also, it's not a diaphram, it's just a dust cover. The round part of the master cylinder fits into the booster. There should be a rubber cover like that on the pushrod from pedal to booster.
1969 Adventurer W100
