axle swap
dodged200
City: kokomo, IN
axle swap
Post by dodged200 »
Would there be any problem putting 1/2 ton axles on 3/4 ton frame and springs?
OregonDodgeboy
City: Nampa, Idaho
Post by OregonDodgeboy »
My first thought is why? :thinking :study
Jeff Easterbrook
67 W200 440/4-sp. Resting
76 IH Scout II
81 MB 240D
Xoloski
Post by Xoloski »
As long as the axle widths are the same, there should be no problem.
you might check the u-joint size first.
Some people do this because their state offers a lower licensing cost for 1/2 than 3/4 ton trucks.
Be careful not to load the now 1/2 ton the same as you would the old 3/4.
A440cuda1
City: Cheney
Post by A440cuda1 »
other than the springs and the dana on the rear, there wasn't a whole lot of difference between the 1/2 and 3/4 set up.
1962 D100 Short bed project
1963 D200 Long bed
1970 D200 Long bed
Many other old rigs, not sweptline related.
dodged200
City: kokomo, IN
Post by dodged200 »
It's a good reason why I want to. I was told on here that a 66 cab wouldnt fit on a 69 frame. So I took the bed off the 69 and I'm swapping the axles because I already bought rims for the 5 on 4 1/2. And the rims I bought were very expensive. So Im just going to take some leafs out of the springs and media blast the bed, paint it and call it my daily driver for awhile.
MBigDaddyM
City: Seattle, WA
Post by MBigDaddyM »
OregonDodgeboy wrote:My first thought is why? :thinking :study
I going to do this because it will be a hotrod, the only thing I'll be hauling both figuratively and literally is @#%! Don't need that extra weight or extra 3 lugs. Get that mildly built 440 in there and away I go. -BD
Delusions of invincibility combined with a strong homicidal urge. I have a kick-your-@#% fetish.
67 D100 CSS
69 Charger
75 Dart Sport
94 Dakota SLT
dodged200
City: kokomo, IN
Post by dodged200 »
And that's a very good reason too. :salut
MBigDaddyM
City: Seattle, WA
Plus with the 3/4 ton camper special springs back there it will the truck the same stance I like my women in (for different reasons) face down, :censored up! :joker -BD
67 D100 CSS
69 Charger
75 Dart Sport
94 Dakota SLT
slick
City: Tucson/AZ
Post by slick »
simple bolt in.. :Thumbsup
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
dodged200
City: kokomo, IN
Post by dodged200 »
And removing leafs from the springs? It's every other one correct? How many is too much?
OregonDodgeboy
City: Nampa, Idaho
dodged200 wrote:And removing leafs from the springs? It's every other one correct? How many is too much?
I'll pass on what I learned when I lowered my A-100 pick-up I had many years ago. I talked to a guy at a spring shop that had many years experience at it. He told me that with my 7 leaf pack, the #3 was a ride height spring and the #5 is a load carrying spring. (Well, he told me exactly what each spring represented, but I only recall those two. :pale )
He advised that I remove the third spring from all four corners, and the #5 from the rears only. The result was about 4" lower all around, smoother ride, and no noticable reduction in payload capacity. Later I hauled a heaping load of 3/4" minus gravel for a friend's driveway, that turned my 3" rake into about a 2" squat. Wish I had picts of it. :pale
:2cents
Jeff Easterbrook
76 IH Scout II
81 MB 240D
dodged200
City: kokomo, IN
Post by dodged200 »
After I do this swap, will I be able to put the Tallzag disc brakes on the front. I shouldnt have any problems right?
