Steering and front spring bushings
Xoloski
Post by Xoloski »
My power steering hydraulic cylinder, connected between the frame and the steering center link rod, has bushings that are worn or missing.
Can these be replaced? does anyone have part numbers?
Is there an alternative fix?
Also, I need to replace the kingpins and thought I should replace all the spring bushings. Is their a kit for this? Will my local spring shop in Tucson be able to fit new bushings? should I consider poly over rubber bushings?
what problems am I likely to run into?
Thanks!
