Brake Adjustment
- guvmentmule
Brake Adjustment
Hey everybody lone time no post, I"m wondering if any body out there can help me I have a 1971 dodge d-100 w/318 2 barrel and I am haveing problems with my brakes either pulling to one side when applied or kinda squeling when comeing to a stop at low speeds is there any way to adjust the Brakes? thanks.
- oneowner71
- City: Fort Worth, TX
There is an adjuster wheel at the bottom of the brakes, centered. If you look at the back of the backing plate, there should be 2 oval rubber plugs (if they are still there) at the bottom of the backing plate to let you access the adjuster. You may want to also look at your brakelines to make sure nothing is kinked or dented, as that can cause the pull.
Step 1 should be to pull the drum and verify the condition of your pads/drum to make sure you have adequate material. If all that is good, put it back together. Adjustment should be possible. You can take a look at the adjuster wheel while the drum is off to get a feel for what you won't be able to see while you adjust.
I usually put the front on stands enough to let the wheels spin, pull the rubber plugs on the backing plate, and then use a brake adjusting tool (or a flatblade screwdriver) to spin the adjuster wheel in the appropriate direction to spread the pads apart. I always run mine out until I can just begin to hear/feel them rubbing on the drum as the tire spins. If you can get that even, it should minimize the pull. With the exception of drum removal, the front and back are pretty much the same.
Thanks, Clint
1971 D-100, 318 3-spd
1970 Dude, 383 / A727
1971 Plymouth Satellite,
2002 Dodge Ram 1500 Quadcab
- Jeffc
Re: Brake Adjustment
Agree with oneowner,guvmentmule wrote:Hey everybody lone time no post, I"m wondering if any body out there can help me I have a 1971 dodge d-100 w/318 2 barrel and I am haveing problems with my brakes either pulling to one side when applied or kinda squeling when comeing to a stop at low speeds is there any way to adjust the Brakes? thanks.
Questions for you...
Do you know when the brakes were
reshoed the last time?
Have the brakes ever worked right
and/or is this something new?
Is there any fluid loss from the master?
any dark stains from the lower side of
the brake backing plate over the tire?
When drum is off----
is shoe getting full contact to the drum
or are there areas not making contact?
make sure there are no leaks in the area
from the wheel cyclinders or axles....
I would be checking all four drums, only
takes one to cause 'pulling'.
Anytime I buy a new truck/car one of the
frist things I check is brakes by pulling
all 4 drums for inspection. 9 times
out of 10 they need a rebuild.
- guvmentmule
Brake Adjustment
Thanks guys for the advice,I'm here in Austin TX and really wish I could hook up with someone or a group for help like this, Thanks again.
- oneowner71
DaddioJoe on this forum is in Austin as well. Not that I can volunteer his help, but you may want to PM him if you still need some help. Brake jobs aren't too difficult, just do one side at a time so you always have one to go to for reference. As far as just questions go, keep on with them on the forum. They'll get answered in as much detail as you need.
Thanks, Clint
