Power Assist (or lack of)
My '71 W100 has the remnants of the power assist, but it doesn't work. Does anyone know where I can get parts for the control valve/drag link assy.? Please, no laughing!
- HighDesertDodge
There is a place that I bought parts from in Nevada, called L&M Powersteering. I think the part that you are looking for cost me $250. I will have to ask my friend if he remembers what town it was in. I think it was Reno.I still have said part, never installed it. Its been sitting on a shelf in my garage for about eight years. Yep, went out to the garage and found it.
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
Steering Valve
I don't know if my previous reply came through; I'm using a loaner pc from the IT dept.
Can you please give me a call asap and let me know if your valve is good and if you'll sell it to me? Thanks!!
Rick Simons
Home-541-935-0659
Cell-559-308-2865
e-mail rns@niroinc.com
Rick Simons
Home-541-935-0659
Cell-559-308-2865
- MarsMonster
- City: Seattle/WA
Drag Link
Hmmm, now the plot thickens; I can see several differences between your system and mine. It looks like your pitman arm is curved; mine is straight. The valve I have is a telescoping unit; the part that attaches to the pitman arm slides in and out of the other section that attaches to the steering arm. Also, the cylinder on mine looks much bigger, but it's painted blue so it may not be original. Finally, the pump I have looks like it came from a small tractor and is shimmed with washers, etc., to somewhat align it. Plus, it uses a remote resevoir, which I know isn't 70's era Dodge. I did find a source that will rebuild my valve, cylinder, and supply a rebuilt pump for $767. I'll post the link in a few minutes. Thanks for the photo!
Power Steering
nfury8, I really haven't looked into the problem in depth; I stopped looking as soon as I saw that the section of the control valve that attaches to the pitman arm is bent. I figured at that poin that the valve probably wasn't working. I also don't know exactly how much assist these systems provide; it may be working after all. I do know the boxes on these things have a ratio of 45:1 or something like that (ok, I exaggerated a little). Here's the place I found that can fix it all up:
http://www.powersteeringparts.com
- oldopelguy
- City: Saint Michael
- State: MN
corvette/mustang
If you're up for a bit of fab-work the valve assembly from the 63-83 or so Corvettes and early 70's mustangs will work as well, but you will need to cut down and thread a non-assist drag arm to screw into th valve assembly. Those units have a lot more assist as well.
If it workes right I'm attaching a pic of one from one from one of the many sellers on e-vil-bay peddling them for @$200 rebuilt or new. The hoses attach on the back end, as opposed to the middle like ours, but that's not a huge deal if you're getting new hoses. On the one in the pic the rod attaches to the left hand side, threaded into the body then locked in by the crimping bolt.
- duracell
- City: Peoria,Arizona
Re: corvette/mustang
would you mind sending me the info on this? it might be something to consider in the futureoldopelguy wrote:If you're up for a bit of fab-work the valve assembly from the 63-83 or so Corvettes and early 70's mustangs will work as well, but you will need to cut down and thread a non-assist drag arm to screw into th valve assembly. Those units have a lot more assist as well.
as always and sometimes not,steve
- oldopelguy
- State: MN
I haven't actually done that myself, it was just a suggestion for people looking around. When one of the stock units on my trucks finally dies I'm going to swap in one of these:duracell wrote:
http://www.sweetmfg.biz/products2.asp?edit_id=33
This is a completely aftermarket valve assembly made for stock cars. It goes between the steering column and the gear box, and controls oil to a remotely mounted cylinder. By it's very nature it's going to require some cutting and welding of steering components, but I plan on doing it in conjunction with a tilt column swap so that should cut down the fab work some. I'm not sure how well it'll last, but assuming the fluids are maintained and such it should hold up all right. They run @$250 new http://www.speedwaymotors.com/p/1963,17 ... ervos.html
but you can find them used for a lot less.
