New E-brake Cable
New E-brake Cable
Anyone know where I can find a new e-brake cable for my 64 /6? THANKS!!!!
- Jeffc
rear wheels type or trans brake type?
You can also have one made at Inline Tube, http://www.inlinetube.com . I had one made there and I was happy with the service and price. You would probably have to send them your old one, or at least the ends. You might also be able to buy one straight out at Imperial Services, http://www.imperialservices.com.
1969 Adventurer W100
Carpet cleaning and e-brake cables?Russ wrote: You might also be able to buy one straight out at Imperial Services, http://www.imperialservices.com.
If your carpet doesn't need cleaning, try this one instead. http://www.imperialservices.netsoopernaut wrote:Carpet cleaning and e-brake cables?Russ wrote: You might also be able to buy one straight out at Imperial Services, http://www.imperialservices.com.
- PowerMan
- City: Auburn
Also for anyone out there with the rear wheel E-brake set up. You can find the set of the two cables at Carquest. Found new ones for our '65 W100 there.
Power Man
Power Man
- PowerMan
- City: Auburn
Try #2511363 (CarQuest). If that doesn't work say so and I'll keep looking. Try this website address: https://www.mycarquesthomepage.com:8443 ... ctId=51051
Power Man
Power Man
