patmcc70
Post
by patmcc70 » Sun Feb 04, 2007 4:19 pm
I need to have the steering box in my 1970 D200 rebuilt.
How do I get it out? Do I have to go through that access panel by the steering column or can it all be done from below?
How about putting it back in?
Thanks for the advise.
mightydodge
Posts: 103 Joined: Wed Dec 31, 1969 6:00 pm
City: Kansas City/Missouri
Post
by mightydodge » Sun Feb 04, 2007 4:26 pm
Depends on whether or not you have power steering but if you have manual, this is how it's done. Remove the bolt holding the pitman arm to the steering box. You can access it from underneath on the outside of the frame. Then loosen the bolt that holds the steering column to the steering gear box. Then remaove the three bolts holding the steering gear box to the frame. Too easy.
tom-adc
Posts: 770 Joined: Wed Dec 31, 1969 6:00 pm
City: LaA
Post
by tom-adc » Mon Feb 05, 2007 9:03 pm
Does anyone sell a seal kit for one of these, manual box. I'd like to pull mine and reseal it.
Snowdogg
Posts: 303 Joined: Wed Dec 31, 1969 6:00 pm
Post
by Snowdogg » Mon Feb 05, 2007 10:00 pm
tom-adc wrote: Does anyone sell a seal kit for one of these, manual box. I'd like to pull mine and reseal it.
JEGS has a manual box in ther MOPAR section that they say will fit. Don't know for sure if it do'es or not.
tom-adc
City: LaA
Post
by tom-adc » Mon Feb 05, 2007 10:14 pm
I just did a check and NAPA shows this part# NOS7481
as the seal. I think I'll just reseal mine and let it go at that.
Underdodge
Posts: 142 Joined: Wed Dec 31, 1969 6:00 pm
Post
by Underdodge » Wed Feb 07, 2007 9:39 am
While you got it apart would be the easy time to do the rag joint. I found them at Pep Boys for $7.00
Always fear Underdodge is here
67 Polara
72 Scamp
