When was the last time you checked?
- City: LaA
The level of oil in your steering box? Book says every 2000 miles but I'd bet its be ages for mine, took a goodly ammount of oil to top it off. Now this along with the lube job last week is making the steering effort even better, I'm going to play with the adjustment on the cross shaft in the morning. There is some slack in the wheel I think will adjust out. One thing lock to lock I don't feel any catches or flat spots so many it isn't to late
- duracell
- City: Peoria,Arizona
most don't realise that the seal for the shaft is bad so when they add gear oil it will leak out. so i took some advice and added white lithium grease (the kind you use for speedo cable's)to what was left in the steering gear. this thined out the lithium grease but kept it thick enough not to leek out any bad seals
as always and sometimes not,steve
- MarsMonster
- City: Seattle/WA
- City: LaA
Book says SAE 90 multi purpose gear lube or if it gets cold 80 wt I had some left over 85 wt so used it,MarsMonster wrote:What type of oil is the gear box suppose to take? I will check mine.
Mars
so far no leaks but it did have to go some place If it leaks I'll do the white grease thing I have a tube of outboard lower unit grease that should work okay.
- Underdodge
- City: LaA
Underdodge those available locally like kragen, Autozone etc?Underdodge wrote:I put a new rag joint in it took out a lot of the play
- Underdodge
- Underdodge
Tom I did a search for rag joint came up with alot of hits try this one
http://borgeson.com/TruckProductDodge.htm or just try the red help isle in your better parts stores like Napa
Always fear Underdodge is here
67 Polara
72 Scamp
67 Polara
72 Scamp
