Frame length
Frame length
Okay guys...got a questiong for you. How long is the frame on a SWB truck?
Thanks much....
Brandon
Thanks much....
Brandon
frame length
thats on a SWB???
measure
I walked my LWB off at 15ft, to check to see if it would fit into a 1957 Garage????
Checked it again.... 15 feet almost on the nose.
Look at it this way.... 114" wheelbase measured
to axle center-lines.... add ~28" from the front
axle center-line to the end of the frame and add
~38" from the rear axle center-line to the end of
the frame
Robin.... ya better check your gait!
I hope you haven't closed on that house yet ....
you may have to blow out the back of the garage.
the frame
length
IF THE TRUCK DON'T FIT, and I have room to walk around it, along with another vehicle, I WON'T BUY lets don't forget the aircompressor the 6' Craftman tool box, need room for work bench, and hopefully very soon a WELDER
