Pulling the 318
- slick
- City: Tucson/AZ
- State: AZ
Pulling the 318
I'm getting ready to pull the 318 out of my truck....Dumb question, but is it easier to pull it with the bell housing still attached or unbolt it at the bellhousing...it's a hydraulic clutch 4-speed...
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
1961 Dodge D100
1964 Dodge Polara
- wideblock
- City: las cruces nm
- State: NM
support the rear if the tranny with a 2x4, and pull just the engine. that damn 4 speed is a heavy SOB. id leave it in if you can. just disconnect the bell from the motor and pull it that way. leaving the bell and the tranny in place. thats the way i would do it. or yank engine and tranny togather. much easier to assemble in the driveway then under the truck. but like i said, the 4spd is a heavy mother. they are a pain to deal with, and i wouldnt if you dont have to.
- Butch Romig
- City: garnett ks
Exactly .....Butch Romig wrote:with a hyd clutch ,you HAVE to pull the bell with the engine,there are bolts inside the bell that attach it to the engine,leave the trans in the truck
butch
Also, unbolt at least one of the crossmember
insulators from the frame. You can't just remove
the 2 large stud nuts and get that crossmember
off.... not without a lot of dicking around and
the likelihood of damaging the threads on the studs.
Are you ready to sell
I was just wondering if you are ready to sell the engine now if so let me know I'm still looking.
