On my 70 D100 with the column mounted A727 there seems to be 2 neutral postions. It is P N R N D 2 1. Actually I don't know if the first N is a neutral or not but it isn't a forward or reverse gear. I am guessing that these trucks only used a light to tell you what gear you are in, as opposed to a needle. I was wondering if this would serve a purpose or if it is something that shouldn't be this way.
I don't plan on doing anything about it now and it doesn't seem to affect the drivability of the truck. I don't drive it much right now because I have no insurance, speedometer, fuel gauge, seatbelts, job, etc.
2 neutral positions
- wideblock
- City: las cruces nm
- State: NM
the N between P and R is wrong. maybe just a gap in the shift, but not supposed to be there. as far as an indicator goes, you should have the clear plasic piece that goes on top of the column with a red needle. thats what they came with, but they do break and fall off.
- City: Glendale,
- State: AZ
Even if the needle has fallen off, I would bet if you crawled under your truck and looked at the shift linkage from steering column to tranny, you would find most of the bushings at their pivot points are sloppy. Good news, there is a fix and it is critical for anyone with a 727 torqueflite on the 69-71 trucks.soopernaut wrote:I went back and looked at it after I posted this. There is no 1. Every gear is off by one position and 1 isn't even accessable. The needle must have fallen off too.
I'll probably eventually go with a floor shifter.
Go to your local Dodge dealer and tell them you need the neoprene bushing that sits in the shift lever where the linkage connects to the tranny. this bushing was used up until 92-93 I have a spare from a previous experience, but the part number on it is only 5 digits, won't match anything in Dodge catalog. Find an experienced parts guy, I think I paid 9. bucks each for 2.
It will tighten up your linkage so you can feel 1st gear kickdown, even without the pointer. Jim
Tighten up the linkage
03 Hemi Ram 2500
