i am looking for a cam thats good for all around stuff. like street&strip&towing.
its going in a 383/727?
what stall should i run?
but i would like for it to have a noticeable idle
any ideas?? let me know
thanks
john
what cam should i go with??????????
- hotrodjohn68
- wideblock
- City: las cruces nm
- State: NM
268H for the mellow, yet lopy idle and good all around driveability. just a shade better then a 383 magnum would have.
280H rumpy idle, needs a slight stall, but not as big as they reccomend. this is what i had in my charger, loped like a biotch, sounded great thru 3" exhaust and hedders, and really pepped up the 383. but its more a hot rod cam, not a truck cam.
http://www.powerandperformancenews.com/ ... gory_Code=
click the links and look around. id go with the 268 for the better low end torque the 280 has a higher rpm range and torque curve.
- City: COS ( Colo )
Hola John
No matter who's hot article that you read in whatever language, they all say to get you exhaust ready first.
Have the local non chain muffler shop measure the inside diam of the exh manifolds and use that inside diam to the rear bumper. When it comes to the muffler, you know to use ~ inside diam on both ends. The longer the high flow muffler is, the better the truck will be liked by others. Have the shop install a cross over pipe about where the flywheel is.
Do this while you figure who's telling you to build a NASCAR truck or a street truck.
Jon
It has been a week since you asked for some guidence on your 1968 383 cubed truck.
What have you come up with ???
As I was re-reading your post I came up with another question. What does a " noticiable idle " requirement have to do with a vehicle that is going to be used on the streets and as a towing vehicle ???
Thoughts ... the average engine speed on the free-way is only about 2500 rpm's.
cam
the 280 duration that Trey mentioned will be good if ya want to be able to hear lope, you'll need lift of more than 265, the big block 383 has always loved high duration with less lope example one cam is 484 lift and 284 duration second cam is 480 lift and 290 duration, in the past when building the 383 it gave better performance with the cam 2 less lift and more duration/ but their isn't much of a way to go wrong its a MOPAR
