A two part question, first how much horse power can a stock 8 3/4 hold and how much power can it hold useing aftermarket internals in the stock houseing?
Also i am unsure about lockers vs spools vs sure grip/posi units. The truck is not going to be a daily driver any more and sometime next year it will have a 550-600 hp shortblock 400 in it. Right now it has about 300 hp in it and i want to get a unit strong enough for the new engine.
~Alex
Power rateing for an 8 3/4
- shaq787
Project truck: 67 D-100
tryin to turn it into a hotrod on a very limited budget.
- City: Lawton
I've heard 8.75s are good to about 600 ponies. The 741 casings in our trucks are the weakest of the 8.75 housings and I think they're pretty stout. At least the one behind my 440 is still living
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride"
I agree with jj , I have put them through the pace with alot of pones , & have seen them behind a Hemi or two , Knew a guy once who put A truck 8/34 behind a full house 427 Ford , because he said he liked it better then the 9in ford
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
67 w100 318 3spd
LAND OF THE FREE
- mopar400
- City: Bloomingdale, GA
It's a good rear and fairly inexpensive. One of the week links I have found personally is cracking the driver side bearing cap (with 500 HP). When this happens it distroys the ring, pinion and usually the case. This can be remedied by installing a billet cap. mopar400
Here is a example:
http://www.markwilliams.com/detail.aspx?ID=609
Here is a example:
70 Challenger 506hp 440, 727, 11.29@120mph
1965 Fury II(in pieces)
- shaq787
Thanks for the help guys. now that i know the 8 3/4 will hold the power i need to diecide between a posi/sure grip, lockers or a spool. I'm not worried about it being a daily driver, just don't want a one tire fire.
~Alex
and nice avatar Mopar400
~Alex
- CSS-Registry
- Administrator
- City: Gainesville, Florida
a sure grip is a great way to hold traction and not loose drive-ability... with the HP you're planning a SG will hold up just fine. all the miles on my HPP 426 truck we never broke a SG. back in the late sixties the old man bolted a dual quad set up with 3.91's in the pig and it would hold strong.
put a spool in it and it is really just a track beastie then - not much street-ablility with them.
Custom Sports Special
& High Performance Package
R E G I S T R Y
R E G I S T R Y
