Will the ring and pinion out of a 73 1/2 ton front
fit in a 63 3/4 tojn frontend
interchange
interchange
- PwrWgnWalt
- City: Butte
- State: MT
Fred;
Assuming that both are Dana 44 axles, they should work. However, there is one area that seemed to change - at least on the Dana 60 axles - that you may wnat to be cautious of, and save yourself a load of headache over:
If you re-use the carrier fom the 1/2 ton, be sure the axle shafts themselves will fit into the carrier properly (same # of splines).
Otherwise, you may have to take the ring off of the 1/2 ton carrier to use on the existing 3/4 ton carrier.
Have fun!
PwrWgnWalt
Have fun!
PwrWgnWalt
