mY dodge is still BANGING, but its not in a gang...
- Slammin69
My 69 is not a gangbanger but its still causing problems. She was making a LOUD bang when i would hit the accelerator so i got a mechanic/friend of mine to look underneath while i shifted it from neutral to drive. He said there was a lot of slop in the rear end. So i pulled the axels and put a new carrier assembly in it. The member that came out was not impessive there were bits and pieces of washer material from the spider gears everywhere and the pinion gear was as sloppy as could be. So after pouring some fresh 80- 90 in it i went for a drive the banging was lessened but still there I'm begining to think the rear end damge is a symptom not a cause. Could it be the tranny tailshaft? i dont think its the u joints but ill replace those anyway. I'm guessing its the tranny.
dirty dodges best be out yer garages!!!
- taintedspeed
incase you havent fingered it out yet, i had a very similiar problem with my 64 ply. i kept one foot on th brake and looked under the car as i went from nuetral to drive and back to reverse. i could watch the d-line turn a complete 360 before it caught, and a helluva racket it made when it did catch. turns out the lockup sprag in the tranny was toasted. i rebuilt the whoe thing while i was in there. before finding this out i replaced the rear end. good luck -Taintedspeed
all mopar all the time
