1971 d500 eng transplant
I have purched a 1976 complete 440 and 727 trans pulled from a 1976 motor home. I plan to install it into my 1971 d500 truck.My truck currently has a running slant 6. I am looking for a way to mount the 440 engine to my existing 4 speed or get a 5 speed trans to mount to this beast. I plan on doing some heavy towing. any help wlll be gladly appreciated.
I assume that it has a 318 in it now, if so you will need a hydrualic bellhousing for the big block.
then the truck type water pump, or industrial.
sits higher up than a pickup or car , so that the fan will be in the right area to pull air through the radiator
