Hello folks,
I don't see this in the archives, so here goes...my application is a '64 d100 with a built slant six and a 3.91 sure grip on an 8 3/4 axle set. I did the A833OD 4 speed swap, now want to try a 5 speed, but not the NP with the granny gear. Seems the NV3500 for a '00 to '04 Dodge Dakota might even bolt directly up.
(1) But I haven't found the gear ratios for a 4x4 tranny I picked up, and hope someone knows or knows a site to look at.
(2) the tranny has a flange on back for the transfer case, but no transfer case came with it. Is this any problem with using it for my 2wd app?
Thanks!
rock
'64d100
swapping in NV3500 (Gertrag HM290) gear ratio and flange qu
NV3500 4.01, 2.32, 1.40, 1:1, .73 Chrysler
http://www.bc4x4.com/faqs/yj.cfm?cat=6&faqid=82
Found it a little ways down. I didn't see it say anything different for the 2wd or 4wd models.
Can't help you on your second question
- westmorgan
I've been told that the slant 6 and the v-8s don't share the same bellhousing. I do know that tranny will bolt up to dodge v-6s and LA, Magnum, and New Hemi v-8s. If you look on page 2 in this forum you will find a thread I started on this subject. There is some basic info that is good to know. I don't know for sure but I would guess that you will need the 2wd version for your truck.
2001 Dodge 1500, Quadcab, 4x4, 5.9L, Auto
1979 Dodge W150, LWB, 360, 727
1977 Dodge W100, Utiline, 440, NP435
1977 Dodge W400, Dump bed, 360, NP435
1970 Dodge W200, Crewcab, SWB, 318, NP435
1961 Dodge D300, Dump bed, /6, NP420
