I've got a 727 that started slipping into 3rd on the way home from work tonight. You can kinda get on and off the gas and make it kinda slip between 2nd and 3rd. It's also "chattering" in reverse.
HELP ME!
transmission:
- cudajimmy
- City: Oklahoma
transmission:
69 Barracuda Notchback 440
61 D100 SWB Poly Auto
- Jeffc
If the filter is clean, fluid is up to snuff, kickdown is adjusted right...........
then you may be looking at rebuild......
sounds like the rear clutch pack.....
- taintedspeed
- shaq787
That sounds like what happened to my brothers transmission (727). He hacked one out of a van siting behind the shop and had a better shift kit installed and now it bangs the gears really nicely. Theres also a way to mod the trany plate by drilling some holes in the passages to get it to shift whenever you move the linkage, no matter how fast you are going. As an example: going into first at 70mph.
just my 2 cents
-Alex
just my 2 cents
-Alex
Project truck: 67 D-100
tryin to turn it into a hotrod on a very limited budget.
