hi, i would like to know if anyone has the torqueing pattern sequence for 64' poly 318 heads and if you know the correct torque that they require.... also what the intake manifold bolt torque pattern is and the torque they require... i know thats kind of alot of info to ask for but i tried looking it up and couldn't find any books or info on it on the internet, i probably didnt look hard enough but im kind of lazy, hahahaha thanks
1966 dodge d-100 1/2 ton project
1987 dodge d-100 ram long bed
Torque the heads to 85 ft lbs. The bolts should be clean and lightly lubed, per the svc manual. The manual doesn't say to do this, but I torque mine in steps. Tighten them to about 60 ft lbs and then to the required torque. The tightening sequence is:
