Magnum Engine bolt patterns
- Floorguy
Do the 93-newer small block Magnum engines have the same bolt patterns as the older small blocks?
- westmorgan
If you are asking about the bellhousing, then yes the LA, Magnum, and 5.7 Hemi all share the same bolt pattern. As far as engine blocks go, I think, but I might be wrong, that there is very little difference between LAs and Magnums other than additional engine mounts on the Magnums.
2001 Dodge 1500, Quadcab, 4x4, 5.9L, Auto
1979 Dodge W150, LWB, 360, 727
1977 Dodge W100, Utiline, 440, NP435
1977 Dodge W400, Dump bed, 360, NP435
1970 Dodge W200, Crewcab, SWB, 318, NP435
1961 Dodge D300, Dump bed, /6, NP420
