I've gotta problem
- cudajimmy
- City: Oklahoma
I've gotta problem
I think it's a broken valve spring, but listen up and tell me what you all think.
Truck: 1967 D100
Engine: 318 with warmed over 360 heads, cam, Edlebrock intake/carb, electronic ignition by 4secondsflat.
Problem: At idle, truck has a dead miss. Put it in drive, take off, and every once in awhile, it'll pop a few times till the rpm's get up. Take off a little harder, it does okay until it shifts, then the motor cuts out. If you let off the gas, and get back into it easy, it'll come up okay. At highway speed, it seems fine unless you do something to disrupt it. Then it starts missing again.
Well?
Truck: 1967 D100
Well?
69 Barracuda Notchback 440
61 D100 SWB Poly Auto
- cudajimmy
- City: Oklahoma
mechaniclese wrote:Could be a flat cam lob. I had a 79 d 150 with a 360 that had a miss like that pull it off an idle it smoothed some, get into and it would pop back through the carb. my
I thought about that, but it'll pick the miss back up at higher rpms.
- Hemikuda71
- City: Oklahoma City
- CSS-Registry
- Administrator
- City: Gainesville, Florida
Re: I've gotta problem
sounds electrical - maybe coil or ignition module to me....cudajimmy wrote:I think it's a broken valve spring, but listen up and tell me what you all think.
Truck: 1967 D100
Well?
i had a 340 valiant do the same thing - it was coil on it.
Custom Sports Special
& High Performance Package
R E G I S T R Y
R E G I S T R Y
- cudajimmy
- City: Oklahoma
Now that you mention it, I DID have the voltage regulator stick open and blow up my ballast resistor right before this started.CSS-Registry wrote:
ok one more thought. Could it be losing oil pressure in one of the lifters? I had a friend that happened to on a 75 318. At idle it would miss pull it up it ran fine. get into it it cut out. Turned out to have a pin hole in the bottom of the lifter. At an idle the oil pressure wasn't enough to pressurize the lifter all the way. As the speed increased the oil pressure came up and it would work fine for a bit but the turning of the cam slowly leached the oil out of the lifter until it collapsed. I don't think it had the best oil pressure. It's a stretch I know put I have seen it happen
- City: Lawton
O.K Jimmy this is going to sound sort of simple but.....change the spark plugs and see what happens and look at the distributor cap and rotor while you are at it, remember that is a very high energy ignition system (hint this is from experiance).
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride"
hint
similiar to what happened to the 83 D150 w/318 I replaced the ballist resistor still same, replaced the ECU, still the same, replaced the magnetic pickup, and it runs better than ever.
- cudajimmy
- City: Oklahoma
UPDATE:
I put my infra red thermometer on the headers, and all were about 495ish degrees EXCEPT number 5 cylinder. IT was 160 degrees. Pulled the valve cover off, and you can push the pushrod on the intake side down with your fingers. Like the lifter has NO pressure to it at all. Lifter is JUNK.
NOW....do I replace just one lifter, or should I replace ALL the lifters? I'm worried about making the cam go flat now.
ANYONE?!?
ANYONE?!?
I'd say all if you can afford it. Make sure that cam isn't rounded off yet.
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
problem
I'd replace all lifters at same time so you don't have to go back and do another, and you can do it without tearing down to cam.
- City: Lawton
Pull the lifter and look at the bottom, if its not dished put a new one in and fire it up. So much for Comp Cam junk .
