1961 Differential Pinion Seal
Snowdog
City: Red Deer
Post by Snowdog »
I've searched the forums, and the parts people have searched their reference books, and we can't find a seal for the diff on my 61' D100. It's the good ol' 8 3/4". Can anyone point me in the right direction?
1961 Dodge D-100
Alberta, Canada
Re: 1961 Differential Pinion Seal
Take it out and look for the seal number stamped into it. Or, measure it up and find one the same dimensions.
BigBlockTrucks
City: Binghamton
State: NY
Post by BigBlockTrucks »
Snowdog wrote:
Sat Mar 23, 2024 1:57 pm
What are the casting numbers on the center section?
741,389,742 ? The seals are still available.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
BigBlockTrucks wrote:
Sat Mar 23, 2024 8:55 pm
Are the pumpkins the same on the early tapered axle housings as the later housings?
jeffc57
City: vancouver
Post by jeffc57 »
657 is the standard in the 61 year, ID by the last 3 numbers on the case. This is the stock 3rd member and the seals should be available
https://imageevent.com/jeffc/techstuff/ ... =4&s=0&z=2
https://imageevent.com/jeffc/techstuff/ ... =1&z=2&l=0
Snowdog
City: Red Deer
Post by Snowdog »
Thank you everyone! All the help sure makes working on this thing a lot more enjoyable.
1961 Dodge D-100
Alberta, Canada
