Hi folks,
Tried to save the old tank, but found leaky, bad fiberglass repair on back side...
found new Van’s tank, fits fine, but it has a filler neck attached. Old one was through a grommet into the tank. Can I cut off the old filler neck and use it with short hose and clamp?
Or do I need the shorter neck with the hose ridge on the end?
New guy, ‘69 camper special new gas tank
Re: New guy, ‘69 camper special new gas tank
Will work fine with hose coupled section. Early sweptline tanks were done that way. Just be sure to get fuel compatible hose.
