HELPPPP - 64 W100 Motor Mount ASAP PLEASE
- dannymontani
- City: Bozeman
- State: MT
Man....I need some bodys help immediately. We've had a big snow here in Montana....not like Sierras....but plenty. My baby....my plow....while pushing hard and long for three days has finally eaten her motor mounts. 52 yrs is good'nuff she said. She's been faboulous. I cannot find anywhere on the web, nor NAPA, O'Reilly, Summit, Jegs, or other's anywhere for the BIG....3 1/2 in tall by 4x4 inch, 4 bolt bottom x 1 bolt top. They ALL only show this...this one from NAPA....#602-1115. These are 4in wide x 2 1/2 in x 1 3/8in tall with one bolt top and only two bottom mounts. Yes, I will weld up something to mount them to but *#%^, what the hell. This is a 64, W100, 318, 5.2ltr, 4x4. PowerWagon. Man....I need these 4 days ago. Thanks so much guys if you can give me a lead of if you have them. (What do they go to????) These are stock on this truck. ???????????????????????????
"If God didn't want us to eat animals, why'd he make 'em out of meat?
1964 Dodge Swepty W100
Re: HELPPPP - 64 W100 Motor Mount ASAP PLEASE
New repros are out there, but not cheap. I don't have a link, but in the past they were on ebay and various other sites. Keep googl'n.
RockAuto is listing several brands
Harold Davidson
Cesspool of knowledge. All kinds of useless $$hit floating around.
1970 D200
You may be able to have a mount made out of polyurethane. Try: Imperial Serices: http://www.imperialservices.net/Truckpart.html
The guy runs the company under:
Steve Charette
Promerican Engineering
5980 Fulton St
Mayville, MI 48744
steve@promerican.com
I know he also makes the bell housing mounts out of polyurethane. I bought a pair, but they were $250 and took a lo-o-o-ng time to get.
While you are looking and waiting, I would suggest fabricating or having a snubber made to keep the engine from eating that mount.
Good luck to you!
Steve Charette
5980 Fulton St
Mayville, MI 48744
Good luck to you!
The rockauto items are different than what the op described for whatever reason.
- chilort
- City: Cookeville
The folks at PolyBushings (https://polybushings.com/pages/moparmounts.html) do great work. I don't know that they have exactly what you need. I have one of the early production truck trans mounts.
My 440 is currently secured with their locking slant 6 mounts.
- PowerMan
- City: Auburn
The motor mount / isolator you need is from pre ~1965.
The super common thin rectangular rubber mount is for the 1965+ when the frame tower was changed.
Wish I could help but I don't have any extras at the moment.
The wrecking yard in Livingston would likely have one but I don't know his winter schedule... only been during the summer.
Livingston, CA south of Modesto? Name of the yard?
- my5thmopar
- City: Columbia
Is the /6 and poly the same in 64? I had to make mine using a 1977 D100 440 mounts. I have a 64 with the old style frame mount. Post a photo, I have 3/4 sets. Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
- PowerMan
- City: Auburn
Livingston MT
Yes the early mount was used for the Poly/small block and Slant six. I converted my '61 from a slant six to a 273 small blockand used the same mount.my5thmopar wrote: ↑Wed Apr 05, 2023 4:29 pmIs the /6 and poly the same in 64? I had to make mine using a 1977 D100 440 mounts. I have a 64 with the old style frame mount. Post a photo, I have 3/4 sets. Craig IMG_3268.jpg
- City: Newberg
Does anyone have a picture of the rubber mount that's needed, either bolted up or separately?
PwrWgnDrvr wrote: ↑Sat Apr 08, 2023 9:33 amAvailable here:
https://www.moparmall.com/MoPar-1734529 ... -40911.htm
For that price it would be better to adapt front rubber isolators from something readily available and cost effective.
- dannymontani
- City: Bozeman
- State: MT
Hey THANKS ALL YOU GUYS your the best. Ya, I'll give a call to Livingston, or just go on safari over there actually. What I've done is to chain around them.....the day after I wrote the post via a suggestion, thank you man. I took measurements and will weld up two blocks and then mount the mentioned mounts from later models....likely...if I do not get them for a reasonable cost. Crikie, could they cost any more. WTF! I have been offline w too many issues to get back here..BUT KNOW that I appreciate all of YOUR inputs. Such a great community.
