Linkage
Linkage
I hope im in the right spot with this. I jumped in my 68 today and coildnt get into first or reverse. I got to second and 3. This happened before and I had to take the linkage off the transmission, shift to first, then hook the linkage up again. That was 2 months ago. Whats the solution for this so I wont need to do it again?
- martincom
- City: Five Points
Re: Linkage
You didn't mention what transmission or shifter you have. I'm going to assume it is a 3 speed column shifter. The steering column mechanism, is worn and needs to be rebuilt. It is a common issue.
viewtopic.php?f=19&t=26016&p=187021&hil ... mn#p187021
Re: Linkage
Yep, totally forgot that part, sorry! It is a 3 speed, three in the tree. Thanks! Ill look into the rebuild.
