Timing
- City: Bakersfield
Timing
I’m having issues with my timing my gear had stripped before so i replaced them and set the timing to factory timing and also replaced the distributor gear, distributor is aiming correctly i believe” the rotor is aiming to the first spark wire but when i try starting it up it cranks but then after a few crank it backfires through the carb what can it be?
- martincom
- City: Five Points
Re: Timing
You could be off with the rotor placement.
1. Remove the #1 cylinder spark plug.
2. Remove the distributor cap.
3. Place your finger over the spark plug hole.
4. Crank the engine over, by jumping the starter relay, if you don't have an assistance (or if you want to stay married).
5. As you feel compression come up against your finger, watch the timing mark, on the dampener, until it is at TDC. If you go past it, you'll have to bring it around two revolutions to be back at the firing stroke. Four stroke engines complete two revolutions for each complete cycle.
6. The camshaft is now at #1 firing position. If your rotor is not, you'll need to lift the distributor/oil pump drive shaft/gear and rotate it so the rotor will be at #1 firing position.
