There are various types of coffee brewing methods, each results in different tastes and flavors. As technology evolves over time, coffee makers are now available for different coffee brewing methods.
How to know which coffee maker makes the best coffee according to your taste? We have done the research, so you don’t have to. Here we are glad to share with you some of the most popular types of machines on the market.
Useful Reference: Best coffee maker
Types of Coffee Makers
1. Drip Coffee Makers
Being the most popular type, drip coffee makers can be seen in so many American households due to its user-friendly operation and a relatively low cost.
How it works: Put cold water in the reservoir and coffee grounds in the filter. The machine will heat the water, letting it pass through a tube to the showerhead. These drops of water then dissolve into the beans, collect the coffee oils, and drip into a carafe.
Pros:
- Affordable
- Easy to use
- Can brew coffee in large quantities.
2. French Press Coffee Makers
For truly coffee addicts, french press coffee helped them get the full-bodied brew with a few simple steps.
How it works: Put coffee grounds in the coffee maker and let it submerged in just-boiled water for a few minutes. After that, slowly push the plunger, which comes with a fine filter, to press the coffee grounds down to the bottom of the pot.
Pros:
- Rich flavor, full-bodied coffee
- Easy to use
- No outlet needed for portability.
3. Espresso Coffee Makers
Coming in bulkier in size and among the most expensive types, this is a high quality coffee maker for coffee shops or die-hard espresso addicts. Espresso coffee maker can brew a concentrated, rich and delicious cups of coffee.
How it works: Similar to drip coffee, this espresso coffee maker will extract rich coffee shots by heating the water and letting it pass through the pressed coffee grounds. Espresso coffee makers come in many variants, from manual to automatic machine.
Pros:
Rich and concentrated shots
Featuring milk frother
Tips: If you want the flavorful cup of espresso, and also the convenience of not having to deal with much tedious control work, opt for automatic espresso machines.
4. Moka Pot Coffee Makers
Moke Pot, also known as Stovetop coffee makers, is a simpler and more easy-to-use than a comprehensive manual espresso machine. This type of coffee maker produces dark, concentrated coffee brew similar to espresso, which goes well with creamers and frothed milk for different espresso drinks.
How it works: Add water into the bottom container, and coffee grounds into the filter at the top. The machine then heats water, let it pass through the beans, and drip to the carafe.
Pros:
- Cost-effective substitution for espresso coffee machines
- Not require filters, hence no need to replace it time to time
Conclusion
With this comprehensive information about the four most basic types of coffee makers, we hope to help you narrow down the options and get the best coffee maker in the world for your needs.
