Torque specs
Torque specs
I was wondering if anyone knows the torque specs for a 68 d100 with the 225 slant 6. I need the torque specs for the flywheel. Also, does anyone have a good way to cross tighten them? I'm guessing just turn the crank, tighten one, turn tighten another and hope it's good enough?
Re: Torque specs
FSM says 60# for flywheel "nuts". Method is simple - if u can't reach it, turn it til u can!
Re: Torque specs
Woops, I actually needed the bellhousing to flywheel torque specs. I ordered a shop manual, is this the one you guys are using?
https://www.themotorbookstore.com/1968- ... SSEALw_wcB
- ozzie
- City: colorado springs
Re: Torque specs
as far as the bell bolts, I never torqued them, just tightened them. never had a problem with them coming apart.
ozzie
Re: Torque specs
hahaha, yep. Man I didnt proof read. I mean pressure plate. Pressure plate to flywheel torque specs.
- swptln
- City: East Brookfield
- State: MA
Re: Torque specs
That's just the supplement, it goes with the 67 shop manual. So, there will be a lot of missing information in that manual, it will only have the changes for 68. It does have all the Specifications in the rear though.68swep wrote: ↑Mon Sep 27, 2021 5:24 pmWoops, I actually needed the bellhousing to flywheel torque specs. I ordered a shop manual, is this the one you guys are using?
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
- swptln
- State: MA
Re: Torque specs
30 ft.lbs. for clutch to flywheel.
Mark D.
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
