Timing cover dust seal
Installing a Fel-pro Timing Cover Set Part # TCS45284. In the set is a felt timing cover dust seal, donut shaped. This dust seal was absent on disassembly and looking at the 318 Poly diagram and associated parts list it's not shown. If this is need, where dose it install? Thanks for info.
Re: Timing cover dust seal
I have determined that the felt seal goes behind the damper in its cup, as the outside and inside dimensions of the felt dust seal matches the dampers configuration. Have a good day.
yes thats right
