part number for 61'tapered non flange axle seals
- City: Wappinger Falls
- State: NY
Hello All,
I read through all posts regarding 61' tapered axel seals and could not locate current part numbers for the inner and outer axel seals.Been looking for weeks. I have had a heck of a time trying to find the correct seals and where to purchase them. Could someone out there please assist. Thanks so much!
- my5thmopar
- City: Columbia
Re: part number for 61'tapered non flange axle seals
I’ll look around and post. I may have saved the old seals. Don’t use the A7 sets (65 up 8.75) they’ll leak, larger inner diameter. You do have the special puller tool, AKA dog bone. You’re going to need a slide hammer or chain with a sledgehammer. PM sent. For others reading, try searching for more popular Mopars of that era. Same seals and such. Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
Do yourself a favor and upgrade rear end to a non tapered version.
- my5thmopar
- City: Columbia
Yup. I was just about to edit. Thanksdodgeboykim wrote: ↑Thu Sep 02, 2021 9:27 amDo yourself a favor and upgrade rear end to a non tapered version.
Look for wheel seal. Napa had them at one time.
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
Rock auto should have the seals. You will need this style hub puller to make life a bit easier and not destroy the hub/drum. As others stated, best to source a complete 8-3/4 flanged axle differential if possible.Good luck.
- my5thmopar
- City: Columbia
I found the seals but, IDK what they fit. My best guess is a 471862 and 6241S. I don’t think I had an issue with getting them. Just walked in to O’s and asked for them. But, as already stated, replace the diff with something else.
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
- State: NY
Hello guys.
I really appreciate all of your timely input. Thanks so much.
The truck is 99% original, so I want to keep the tapered axles even though I know they are a handful.
I already removed the axles and third member.
The axles actually have a wear mark from the old seals, probably 1/8 wide.
Anyone out there have them machined?
I don't know how easy/expensive they are to find, buy and ship.
Also I saw there is a sleeve that can be used to cover the groove.
Its a 60 yr old truck. If you find them from another truck, they're still old as dirt with 60 yrs of wear on them. What's the point???
Find an old school shop familiar with old tech and they can answer the sleeving question.
Wildcat auto wrecking might have them and might have info you need, there a mopar only yard and have suff back to the 50's. ain't cheap but if you can't find it they may have it Sandy Oregon 503 668 7786 Tuesday to Friday
- my5thmopar
- City: Columbia
chriscodd01 wrote: ↑Sun Sep 05, 2021 1:09 pmHello guys.
Post a picture so we can see how bad. Most diff seals are .5 and others .375. Old mechanic trick was to shim or use a wider seal if the grove was too bad. I’ve done both myself without issue. If ya really need it original, you’re going to pay to get it right. Not sure about the speede sleeve for a tapered axle. Craig
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
- State: NY
Hello guys,
I am having some trouble posting the pictures. I will work on them tonight.
- State: NY
Hello guys,
I am testing this out to see if the pictures come out. If not I'll resend.
Chris
Chris
- State: NY
Hello guys,
I got my tapered axles back in. No leaks, yet. Turns out the new inner seals are not as wide as the original inner seals, so they sit perfectly between the bearing and groove. Problem solved, no need for Speedi-sleeves. Here are the original and new part numbers. Here is a nice site to look up part numbers for seals https://www.allsealsinc.com/pdfs/Timken ... _Guide.pdf Thanks all
Original inner axle seal---DCPD 1139897. New inner axle seal---National Seal (TIMKEN) 471862 or (SKF) 14423
Original outer axle seal---DCPD 1409902. New outer axle seal---Napa (SKF) 14359
Original axle bearings---TIMKEN 25880. New axle bearings---TIMKEN 25880
Original axle bearing race---BOWER 25821. New axle bearing race ---TIMKEN 25821
Original Pinon seal---1738831. New pinion seal---TIMKEN 5126 or Napa (SKF) 18708
New Pinion Yoke 7260 series from DennysDriveshafts.com
